Best Moblie Antenna for OTR Truck
Discussion in 'CB Antennas' started by ctvanover, Oct 9, 2016.
  1. 543_Dallas
    543_Dallas
    Expand Collapse
    Jul 25, 2011
    1,239
    1,211
    Try again. That's the part I didn't like.
  2. HARDROCK
    HARDROCK
    Expand Collapse
    Mar 22, 2011
    169
    32
    Db I would like to see your view on the conjugate match and maximum power transfer.
    My understanding is the system as a whole is resonant.
    This is when matching at the feedpoint of the antenna accomplishes 50 ohms at the
    source and at the antenna for maximum power radiated.
    This is why Low swr can lead you down the wrong road if the system is not matched.
    The maximum power theorem does not have to be resonant.
    Understanding the theorem is the key. Start with a resistive load then add some reactance
    to the load then add a transmission line. Remember that the source impedance is an
    integral part of the theorem. Also note that the conjugate matching theorem assumes
    zero losses except in the source and load resistances. What that means is that a system-wide
    conjugate match cannot exist in the real world since there are always losses in the
    transmission line. We cannot know if we are transferring the maximum available power
    to the load (antenna) unless we know the losses at each point in the system. Walter
    Maxwell was right about lossless systems but a little off for real world systems. Walt
    conjured up a "one-way conjugate match" to try to compensate for the real world
    conjugate match but that concept has holes in it. The fact is that in the real world
    we can create a conjugate match point anywhere we choose by installing a matching
    network at that point, i.e. each conjugate matching point requires a separate matching
    network at that point.
    Tony
    #137 HARDROCK, Jan 10, 2017
  3. HARDROCK
    HARDROCK
    Expand Collapse
    Mar 22, 2011
    169
    32
    In most cases the use of feed-line SWR alone to
    indicate antenna efficiency is invalid, because
    SWR indicates only the degree of mismatch, not
    efficiency.
  4. The DB
    The DB
    Expand Collapse
    Aug 14, 2011
    1,621
    693
    In M. Walter Maxwell's books he addresses this. The first of his Reflections books this is section 19-4, in the second and third of his Reflections books this is section 24.5. This is taken from Reflections 3.
    This is where it ends in Reflections, however in Reflections 2 and 3 there is a reference to Appendix 8 and Appendix 8A which is another way of calculating the same thing as the figures he mentioned above. However, in Reflections 3 there is another section that discusses this further.
    He then continues on for nine and a half pages which I am not going to type up here for several reasons, although it is a good read. I will, however, summarize.
    When loss is present in the components this loss will change said component's reactance. This is where the claim comes from that a conjugate match can no longer exist. However, according to Maxwell that is where said claims stop.
    Maxwell then goes on and talks about adjusting the reactive elements individually to compensate for their loss resistance, in effect "tuning to resonance". For the record, the method described mirrors how ham radio operators use their antenna tuners. I'll quote another part of it here.
    Essentially, the conjugate match becomes directional. As long as the system is tuned to be a conjugate match with the source on one side and the load on the other, the conjugate match still exists. If something changes, say, you stop transmitting and start receiving, effectively reversing the source and the load, the conjugate match doesn't exist, in the case of this example, as long as you are receiving.
    I hope this helps.
    The DB
  5. HARDROCK
    HARDROCK
    Expand Collapse
    Mar 22, 2011
    169
    32
    CTR you mentioned one THING.
    The subject is field strength.
    You had mentioned earlier that applied power and FS was certainly a better way to test for efficiency.
    Will you explain the proper way of tuning a mobile antenna via FS. ?
    Tony
  6. StrangeBrew
    StrangeBrew
    Expand Collapse
    Aug 15, 2011
    511
    375
    One thing to keep in mind is that all this discussion is only relevant if efficiency is priority one, for many less serious operators priority one is to present the radio with a match that won't cause damage when you key it up. In these cases good enough really is good enough as far as getting out is concerned and for these people a simple SWR meter is more than adequate for the job at hand.
    I only mention this because a couple comments here seem to be bordering on putting down users of SWR meters, they may not be the best way to tune an antenna out there but the best isn't always needed.
  7. The DB
    The DB
    Expand Collapse
    Aug 14, 2011
    1,621
    693
    No argument here.
    With all due respect, you got it backwards. It isn't people who use SWR that is being put down, its people who use "resonance". At least as far as my posts are concerned, if you picked up that I was talking down to or about people that use SWR, you should consider re-reading them.
    Let me break it down for you. There are two methods of tuning an antenna, lets call them method1 and method2. CTR and I agree that you won't notice the difference between using the two different methods. However, CTR says you should use only one of those methods and that he doesn't get why anyone would ever use the other method, and is almost to the point of talking down to the person who defends using said other method. My point is what does it matter which method you use if you won't notice the difference anyway?
    In my posts, SWR was not talked down at all, and if you got that impression you either misread, misunderstood, or read into said posts. I have asked over and over what difference does it make if you won't notice the difference anyway, but have yet to get a good answer to this. All I get is CTR making fun of people who tune with resonance, and some comments that sound technical, but are really not relevant to the question at hand, and really make no difference in the end. If I need to I can go get a bunch of quotes to demonstrate this, they are all there in this thread.
    All I want is a good answer from CTR, but all he has done is talk around the issue, as well as talk down about people who disagree with him.
    Now if it is other people's posts you are referring to I have no comment.
    The DB
    543_Dallas likes this.
  8. StrangeBrew
    StrangeBrew
    Expand Collapse
    Aug 15, 2011
    511
    375
    Not really calling anyone out in particular, and it definitely wouldn't be anything you said. It's just the "if it's not the way I prefer it's wrong" thing that has a way of creeping into threads like this one. Just wanted to put up a reminder that we don't all have the same goals in this hobby, what doesn't work for one purpose may be just fine for another.
    Sorry if I offended anyone, I certainly didn't mean to.
    338_MtRushmore likes this.
  9. 543_Dallas
    543_Dallas
    Expand Collapse
    Jul 25, 2011
    1,239
    1,211
    CTR is one of those gurus that should stick to blogs with commentary disabled. He wants to preach but doesn't do well when asked too many questions.
    The DB likes this.
  10. The DB
    The DB
    Expand Collapse
    Aug 14, 2011
    1,621
    693
    No offence taken.
    The DB
  11. HARDROCK
    HARDROCK
    Expand Collapse
    Mar 22, 2011
    169
    32
    Db that helps. Thanks.
    Is the grid dip meter a better way for finding resonance ?
  12. HARDROCK
    HARDROCK
    Expand Collapse
    Mar 22, 2011
    169
    32
    Db that helped Thanks.
    Yes that is how we benifit and Learn. Maybe he will answer.
    Tony
  13. 543_Dallas
    543_Dallas
    Expand Collapse
    Jul 25, 2011
    1,239
    1,211
    We benefit and learn from him dodging questions and talking down to people? Do you even read the things you respond to? :ROFLMAO:
  14. HARDROCK
    HARDROCK
    Expand Collapse
    Mar 22, 2011
    169
    32
    If you look above what i wrote you will see that i am agreeing with The DB.
    Yes means he should answer the question and stop going around the questions
    with irrelevant answers.
    So to answer your question Yes.
  15. 543_Dallas
    543_Dallas
    Expand Collapse
    Jul 25, 2011
    1,239
    1,211
    Sorry about that, I misunderstood you. Might have had something to do with all the CTR cheerleading you've done in the past. I couldn't imagine you ever questioning the integrity of the prophet.
Share This Page
