Celebrate or not? Funky SWR reading
All of these are awesome points
I'm going to try and get my own swr meter and put it on my antenna
That is clearly the best way so there is no speculation
To answer the question thought, there was no recalibration to my knowledge
He went home and tested it on someother gear same way and show 3 on uhf
So I'm almost positive it was a faulty piece of gear somewhere
Ill repost when I can get my own swr. I might drive to hro myself today
I just got a Workman VHF/UHF SWR and Pwr meter for like $25 on Fleabay. It just came in today so I hooked it up and it seems to work pretty well for an el cheapo. Just an option for ya to look at for short money.
And you do need to set it correctly using the set position on the switch for each band .
Yea thats what im going to do
Good call
how does it work? I was afraid to buy a cheap one but yours works well?
Good call
I'm hoping it is doing the job, I checked my SWR and power on my mobile and base and it seems to work Ok, but I have nothing to check the results against. I'm sure its doing the job just fine.
Ok so i bought my own swr meter finally
just a little scx 40
Here is what i got
I got a nice 1.5 on 2 meters and something different on UHF
ITs a cross needle type and when the needles come up on uhf
if they were actually long enough the needles would in theroy cross a little over 2
But they cant cross because the needles are not long enough on the scale
If i put it in low power it looks like it is the exact same thing just a bit over 2 but they do cross because the forward power needle is going up so high
So can one assume its ok? is like 2.1 2.2 aceptable or no?
im going to try and post a picture
And here High power
As you can see if the needles were long enough they would touch just over 2 ish
Is this acceptable
kb1ugx
No pictures are shown. Can you take a picture of the setup? Do you still have the dummy load available? Do you have other coax you can use? Have you tuned the antenna yet?
SWR 2.2 won't kill anything, and I bet we can make it better.
jcm
And here High power
Is this acceptable
Sorry to resurrect an old thread as my first post, but may I offer a tip? In the second image (High Power) you will be able to use the meter properly by pressing the small blue button to switch the scales, at least you could see where the needles cross.
The switch will allow you to move between the 30 and 300w scales.
Regards, Andy
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
