A blown zener diode, I think.... But check for brown spots under r201.I have the right voltage going into the voltage reg but not the right voltage coming out. What else could cause this even changing the voltage reg no difference?
Could I sub NTE152 (or TIP31C) for both parts at TR201 (C1061) & TR202 (C1419)View attachment 20303Congrats, you traced thru the power supply. VR201/variable resistor on that same ac/dc power supply board will adjust the voltage output to the radio board. You will want to adjust VR201 with a voltmeter to read 13.8v. at the radio board. You can check the voltage output either on the emitter of transistor TR201; or where that wire goes to the radio board.
I think it would be best to find an equivalency document online and see if they are subbed by the NTE part.Can I sub NTE152 for both parts at TR201 (C1061) & TR202 (C1419)
Stress is getting the better of me... sigh
They both cross ref. to NTE152 thank you sir. I bought 'em and going to try nowI think it would be best to find an equivalency document online and see if they are subbed by the NTE part.
