Does anyone have the Icom SM 8 desk mic Specifications??
tuner
229
41
38
Canada
I've been everywhere I can think of on the web, and I'm having no luck finding the specs.
Any help would be much appreciated. Thanks ;)
Thanks TBA, I have a Icom 720a that is missing a mic. I looked up on the Icom site what mic matches with what rig. For mine it has Hm7 , SM 5 , SM8.But it did not have the SM 30 on the list . I was told that a SM 30 would work fine. Id just like to be certain before I buy a new SM 30, that it will work . And basically be able to look at all 3 specifications and compare :)
Here are the specs for the SM30 desk mic. Hope this helps.
Reactions: tuner
I can't say for sure, but I know the SM-20 and SM-30 works on the IC-736. The SM-8 is stated to also work on the IC-736. Therefore one might *expect* the SM-8 would work on all of them. It has been my experience that ICOM has held steady in that area. I will see what I can find however when I get some free time.
Reactions: tuner
From the SM8 manual.
Read line 5 of the pic below. States the SM8 mic can work with all Icom radios due to the high/Low output switch.
The SM-30 should work jusr fine. I've found that most Icom mics are compatible with other radios from Icom. As long as it's the same mic element and the same impedance, I would think it would work just fine.
Reactions: tuner
No problem. Keep updating as to how it goes and what you end up doing. Have looked at the SM30 as well as a host of other mics as well for my IC746. But for now it sounds pretty good with the stock HM12 mic and my voice. Get good audio reports all the time. Guess I must have it set up just right.
At any rate. Keep us posted. And have a good one.
73 and God Bless
