galaxy 98vhp
Discussion in 'CB and Export Equipment and Accessories' started by roger460xvr, Apr 16, 2017.
  1. roger460xvr
    roger460xvr
    Expand Collapse
    Feb 7, 2016
    42
    3
    could you use the galaxy 98-vhp with a donkeystomper hd-hg-2879 amp if I turned the power down on the 98-vhp to around 90 or 100watts driving it??
  2. ExitThirteen
    ExitThirteen
    Expand Collapse
    Grumpy and Cranky
    Apr 18, 2008
    1,605
    866
    How many transistors does the amp have?
    ~Cheers~
    LeapFrog likes this.
  3. roger460xvr
    roger460xvr
    Expand Collapse
    Feb 7, 2016
    42
    3
    2-hg,2879
  4. ExitThirteen
    ExitThirteen
    Expand Collapse
    Grumpy and Cranky
    Apr 18, 2008
    1,605
    866
    You'll smoke those in short order. 30-40W PEP max is all the HG's will be able to withstand, unless there's a massive swamping circuit on the input side. The HG's aren't as rugged as the Toshibas.
    ~Cheers~
    rabbiporkchop likes this.
  5. Robb
    Robb
    Expand Collapse
    Yup
    Dec 18, 2008
    10,377
    2,134
    If you must have a Galaxy; then any number of them will fill the bill. It doesn't need to be a high power radio to power that amp. In fact, you will most likely smoke it, as Xit13 pointed out.
    Still want to use an amp and a Galaxy? Then you might consider a Galaxy 949, 959, or 979 - all of which have SSB mode and will drive that amp just fine with 20w input power into the amp.
    Or perhaps you want a radio that is stable on SSB - which the Galaxy radios cannot provide? Then I'd suggest any number of Uniden radios that have SSB, like the five pin Cobra148GTL, Grant/XL, Grant/LT, PC-122/XL, PC-244, or even the new Uniden 980.
  6. roger460xvr
    roger460xvr
    Expand Collapse
    Feb 7, 2016
    42
    3
  7. roger460xvr
    roger460xvr
    Expand Collapse
    Feb 7, 2016
    42
    3
    I have a galaxy 98-vhp that's in my dump truck so I will leave it there..in the house I have a 959b-pro that a got from bells cb shop here in florida...1-6 carrier.12-33 peak so I will use that for my driver on my amp..thanks for all the help.
  8. 9C1Driver
    9C1Driver
    Expand Collapse
    Aug 13, 2008
    2,923
    693
    You went all in and bought the top of the line hot rod radio, if you want to add an amplifier it will have to be something like a 6 or 8 pill. Trying to run a 275 watt radio into a 350 watt amplifier will never work.
    Even if you could de-tune the Galaxy 98 so you could run that amplifier no one will ever notice. Your already at 250-275 watts with your radio, your next step up in power will have to be 500 or more watts or you won't gain anything.
    rabbiporkchop and BBB like this.
  9. roger460xvr
    roger460xvr
    Expand Collapse
    Feb 7, 2016
    42
    3
    I;; stick with the 959..with the 2-pill
  10. BBB
    BBB
    Expand Collapse
    Jan 17, 2012
    729
    355
    Take the leap. Fool you friends. Get a 4,6 or 8 pill high drive amp :LOL:
    I guess you could always get someone to put a switch on the back of the radio to turn off the built in amp in the Galaxy VHP. Only issue is that if you accidentally leave the amp in the radio ON = other amp goes "poof"
    This is how someone else did the Galaxy 94 HP amp bypass mod. Should be similar in the 98 VHP model:
    #10 BBB, Apr 19, 2017
  11. roger460xvr
    roger460xvr
    Expand Collapse
    Feb 7, 2016
    42
    3
  12. roger460xvr
    roger460xvr
    Expand Collapse
    Feb 7, 2016
    42
    3
  13. roger460xvr
    roger460xvr
    Expand Collapse
    Feb 7, 2016
    42
    3
  14. roger460xvr
    roger460xvr
    Expand Collapse
    Feb 7, 2016
    42
    3
    what size amp could you drive with the 98-vhp
  15. rabbiporkchop
    rabbiporkchop
    Expand Collapse
    Jan 18, 2007
    1,319
    349
    9C1Driver likes this.
Share This Page
