Wavrider it was not grid I looked back at switch it is plate that shows 80/90 ma when keyed sorry had a brain fade moment. This plate ma is with no radio hooked up just on bench but me keying up with my pushbutton switch I made and put in a pill bottle. I have checked voltage on top of tubes and its good about 2200 volts I have been extra careful with this amp always drain caps before touching anything. OK When I turn on amp relay not keyed and grid,plate show nothing HV shows 2100/2200v on meter. When I key amp relay engages grid shows 0, plate shows 80/90 ma and HV 2100/2200v and when I unkey pushbutton relay still keyed grid 0, plate 0 and HV 2100/2200v now every time I push button plate goes to 80/80 unkey it goes to 0 but relay still keyed until I turn off power and turn it back on. All these test into a antenna but no radio . I have not used a radio yet til I can get relay problem fixed with your help. Thank You for your help Jimbo165
The amp only stays keyed "AFTER" you key it with the switch?
Going from memory here, 110 vdc is what is on that keying circuit.
The keyer switch will have to connect the two leads of this voltage to make the amp key.
When you unkey the amp stays keyed but no Plate current?
I would try another Keyer, or just another rca jack and short it together to see if the amp keys and unkeys.
If it still keys then the keyer switch is eliminated and will move on to other circuits that may or may not be causing the problem.
On your schematic the link i posted at the bottom left you will see
a 120v ac and a BLU this is the keying voltage coming from the transformer.
D 17 rectifies it to a negative DC voltage, just follow that line around to your antenna relay coil. RL1.
This voltage continues down to r16 and then to the antenna relay ( the keying switch.)
I am thinking it may be your keying switch. Or a tube.
