Any one know what filters or such I need to fix a bleedover problem? Here is my situation, I had my Maco 5/8 mounted on a wash post for three years with no bleed over except for every once in a while depending how strong my TV reception was. I have a set of rabbit ears for TV reception. This is using a 2970dx and no bleed what so ever when using my IC-7000 on 10 meters or vhf/ uhf and also my vhf HT.
Ok, I finaly get my 36ft tower up with the 5/8 on top, ground the system use Davis bury flex low loss coax and now I get I bleed the TV so bad I get yelled at from my wife for messing the TV up when she is whatching it. this is with my HT, IC-7000 and 2970dx.
Is this strange or what. My HT, this is crazy. It is on low power, 500mah vhf and never did this befor.
How could putting my antenna up cause all this?? anyway, what filters and where do I put them?
Thanks,
AP
Thanks,
AP
