It's out !! RCI 2970 N4 200/400 watts
Discussion in 'CB and Export Equipment and Accessories' started by Wire Weasel, Jul 16, 2015.
  1. 9C1Driver
    9C1Driver
    Expand Collapse
    Aug 13, 2008
    2,880
    672
    Wow, you got some $$$$ tied up in that radio for sure when you consider the purchase price and Toshiba final upgrade.
  2. 43Echo695
    43Echo695
    Expand Collapse
    Oct 19, 2008
    68
    ..Thanks Mudduckmobile.
    So with the amp switched off, is it just like a 2950DX?
    Also, how hot does it get when working at high PEP?
    With the amp switched on, of course : )
    73's
  3. NightOwl326
    NightOwl326
    Expand Collapse
    Nov 3, 2013
    60
    17
    Dead silence.........
  4. Mudduckmobile
    Mudduckmobile
    Expand Collapse
    Oct 5, 2015
    490
    159
    I could not find my notes on the N4, So I ran the N4 up on the Bird.
    With the amp. off:
    LOW {POWER MODE} AM: 1/2w - 4w. Peak 30w / SSB Peak 25w
    With amp on:
    HIGH {POWER MODE} AM: 10w - 100w Peak 460w / SSB Peak 465w
    43Echo695 likes this.
  5. Mudduckmobile
    Mudduckmobile
    Expand Collapse
    Oct 5, 2015
    490
    159
    May be it was not the best money spent....but I would not un-do-it.
  6. Mudduckmobile
    Mudduckmobile
    Expand Collapse
    Oct 5, 2015
    490
    159
    How hot does it get? In stock form I can not say I have never ran it with out the added 120mm fan.
    When the rig comes on, the fan comes on. I was told by a good friend that its the safe way to go and he has 2 of them and 1 N2 he made in to a N4 sometime back. The two little fans inside are set to come on when I key the mic, and the 120mm fan comes on the the rig is powered up. I have ran keyed down, running my mouth 10 mints. on High power on SSB and not had any probs. On AM the longest I have keyed was about 6 mints running my mouth, at home as a base I push my 16 trans BBI box nice and slow.
  7. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    725
    104
    I'd like to hear more about where you fiited the N4 in your Ram with center console. I believe my 15 Ram is same setup. Time's like these the jump seat option would have been more accommodating , don't you think?
    Not sure if my first N4 had issues but even on half or less power, the radio display of the RCI would dim on TX. I had connected the N4 via 8 guage directly to battery. Truck's got a 180A alternator.
  8. Needle Bender
    Needle Bender
    Expand Collapse
    ...he thinks it's funny that I stepped in it
    May 15, 2010
    1,401
    285
    You should write beneath that avitar,
    "...Is it safe?"
    Limeybastard likes this.
  9. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    725
    104
    Hahah , oh yes!
    Needle Bender likes this.
  10. rabbiporkchop
    rabbiporkchop
    Expand Collapse
    Jan 18, 2007
    1,210
    314
    Amazon is cheaper.
  11. Bow
    Bow
    Expand Collapse
    Bastard Modulation Engineering
    Aug 13, 2008
    133
    36
    For that kind of coin, I'll buy an Icom...
  12. Needle Bender
    Needle Bender
    Expand Collapse
    May 15, 2010
    1,401
    285
    NOW you, too, can have TWICE the heat causing instability in your reference oscillator! Be the first on your block to waste $650 on a crappy single-stage radio with near ZERO features most have come to know & love in their similarly priced HAMateur rigs!
    ...but thank you for sharing ;)
    ExitThirteen, Bow and n8fgb like this.
  13. w9cll
    w9cll
    Expand Collapse
    Jan 19, 2013
    2,873
    1,490
    Total waste of money. I agree with NB 100%
  14. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    725
    104
    Should be alright, unit is located in truck with ac on 99% of time and heatsink is open to the ac duct area in footwell.
    In any case, just like home audio amps, i rarely drive the dial to max output anyways by habit. Figured I'd get near N2 figures ( stock ) on the N4 without having to push linear hard. Isnt it.
  15. undertaker
    undertaker
    Expand Collapse
    Undertaker
    Apr 5, 2006
    1,514
    358
    I don't run any of my radios wide open. Just my choice I have good tunes on them so I don't need to...
Share This Page
