Hey guys I need a new linear, I was wondering if I should go witha texas star, a midnight special700 or a dave made, any help. I run a connex 3300 hp radio, with a 102 inch whip but may change to a sirio 5000, what are y'all's opinions?
A Sirio 5000 is 6dB over a 1/4 wave?The 102" whip is a fine antenna however if you can get the Sirio 5000 mounted on the roof it'll probably perform better. A Sirio 5000 on the roof mounted properly compared to a 102" mounted low on a bumper bracket quite poorly could give you as much as 6dB gain over the 102" which is equivalent to running a 200W amp!
On 10/11m?I've worked all over the world DXing with 100W however 100W is only half a S point over the 45W you're using now so you'll be wasting your money buying a 100W amp.
Texas Star amps don't work on AM?Only get the Texas Star if you plan on running ssb.
On 10/11m?
If you have 5 people with equal conditions trying to make a contact and you key up with more power, who do you think is going to get their handle called?
So you're comparing a half ass installed 1/4 wave to a perfectly installed Sirio5k?Read the rest of what I said as that is the most important part.
The difference between 100w and 7kw is over 18dB100W is plenty enough. Anything else is just overkill.
But if your antenna isnt very high the amp will help you be heard further.
Yes because most mobile antenna installations are half ass.So you're comparing a half ass installed 1/4 wave to a perfectly installed Sirio5k?
Do I think contacts are made worldwide on a few watts? Sure, depending on the band and the conditions it can be done on a coat hanger.
