pride dx 300
bigdawg46992
Mar 31, 2011
52
I just got a pride dx 300 and it wont do over 350 watts and i know it will do more anyone have any ideas what is going on with it
Replace the tubes ;) I cant remember offhand what tubes are in that amplifier if your not sure I can look it up in one of my books.
4cx250b is the tube
Look at input vswr at the amp, this can cause low power out.
cb tricks has the schematic and I think user manual for this amplifier.
They are a decent amplifier and provide good service as long as they are not over driven.
Keep the drive level low.
Anything over 125 watts carrier with that amp will be nothing but useless distortion. Peak in the 400s. They will do more for a very short time as you sand blast the cathode material away.
Very easy amp to overdrive and screw up.
About 15 watts max is all this amp can use. The KW One had an antenuator on the input so it can take a 100 watt HF rig.
Rich
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
