What I remember about this particular amp is the same as all the other RM Italy transistor amps. You have to keep the drive really low. What kind of power are you putting into it?
73,
Brett
73,
Brett
According to the manual 1 to 10 watts AM or FM. Read that as dead key power since FM does not change in amplitude with modulation.What I remember about this particular amp is the same as all the other RM Italy transistor amps. You have to keep the drive really low. What kind of power are you putting into it?
73,
Brett
I printed out both of the schematics and compared in a couple of places and the reference designators are the same.I have most of the test gear needed just not any real voltages to go by and a few differences in the schematic I am going by this one
Aww shucks, now I'm starting to blush. Thanks 222DBFL.Redlight, Tallman is good people and knows those RM Italy amps pretty well. He will get you an answer. He has worked on a few of those RM Italy amps from what I have heard.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
