The Yaesu GS50 and GS65 bearing are relatively cheap at $55-70.
May have to go with flat top and bearing plate up top..
View attachment 27515 I made a hazer for my Rohn 25 I bought a Yaesu rotor thrust bearing and my 100.00 rotor has worked for almost 2 years. A bearing is well worth the price paid to save a rotor. I have a 4 element Maco flat side and an IMAX on top. Works great.in case your wondering the hazer rides up and down the tower with a winch and cable.
Channel Master CM 9521A Complete Antenna Rotator System with Infra-Red Remote Control for TV Antennas. But I paid around 100.00 now its 219.00 and they have another model for around 150.00 Channel Master CM-9521HD Complete Antenna Rotator System with Outdoor Drive Unit, Indoor Control Box and Remote Control - TV, HAM, CB, WiFi, Radio Reception. looks nicer than mine..
also 3 wire cable is less than 6-8 what ever yaesu uses.
Start at 1/2 way and agen at 3/4 for a short 50 ft tower.How high up a lay down tower should you anchor your cable? Say the tower is 50ft, would an attachment point under 20 feet be alright?
is the moon racker 4 off 40 east youres?How high up a lay down tower should you anchor your cable? Say the tower is 50ft, would an attachment point under 20 feet be alright?
Ok sean it and said may be yours .No sir. I'm in the deep south, deeper than that.
