TH-D72 Echolink
turbojet
Jul 19, 2011
Anyone with success setting up a Kennwood TH-D72 to work with Echolink on a PC? I mean which interface did you use? Rig Blaster, etc. I can set up the radio and the program.
Thanks :bdh:
using an ht as an echolink node is not a good idea. since the radio would spend much of the time in transmit mode handhelds tend to overheat where a mobile radio can do full duty cycle on low power.
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
