The only good electrical reason for using a shortened antenna is because a full sized one won't 'fit' for some reason, or it's more convenient. There are two 'other sides' to that coin that you should keep in mind. One is that whichever is mechanically 'better' will probably do 'better'. And, when you shorten it's length you will also be 'shortening' it's radiation ability (shape of the pattern). The best of the bunch would be the one that works best for your particular circumstances. Which one's that? Beats me, you tell me which would be more suitable for you.
Thanks 4 the replies. i like
the 5ft skipshooter it is what i use
i have a friend that has a volvo
tractor. i was wondering if there
would be a difference in the 4.5
and 5ft on the back of cab. thanks
for the input. the question was
answered by the pattern not being
as good on the shorter one.
