I wanted to show everyone what an NPC/RC (diode/resistor) mod looks like on a scope, and the distortion that it causes. So I went over to F.G. Best, where we took a Galaxy off the shelf, and applied the mod to it. We then ran a test tone through it (so the signal pattern shows the easy to see sine wave) before and after.
This first pic is of a properly modulated AM signal with no NPC/RC mod. Note the nice symmetrical pattern.
Now this is with the NPC/RC mod applied. I took a pic of the radio so you can see that the mod is there. This is also an "extreme" NPC mod so it's easy to see in the tiny picture on the internet. We did a more typical one as well, and the results were the same, just not quite as dramatic.
Shot of the mod:
What it looks like on the scope:
Notice how the negative peaks (the part of the signal closest to the X axis. It's at the center, not the bottom of the sine wave) are totally trashed. This gets represented as distortion under normal voice operation.
Here's one last video clip of the mod being applied then disconnected while a steady tone is running. If you turn up your speakers, you can even here the tone change frequency as it distorts when the mod is applied and then disconnected.
Click here for video clip
Hope everyone finds this educational and revealing.
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=moleculocdx363>MoleculoCDX363</A> at: 12/20/04 9:20 pm
Shot of the mod:
