When I put in the settings Rig :none everything works but no possible to set fake it
when i try to use in the settings rig: yaesu 1200dx possible to set "fake it" but nothing works
can i use that rig and what about the settings
thank you for advice on3bm
Do you really need to use split? If you're just doing casual FT8, you don't need split. If you're contesting, then you probably need it. I don't have that rig, so I can't comment on the right setting for it.
Yes, you must use split (or fake it) to don't transmit on filter edges.
@on3bm set "fake it" in software. Than set red cursor on 3000 and press TUNE.
You should see freq on display changing on TX.
