100 ohm dummy load
they are parallel
Then you have a 50 ohm dummy load not 100 ohms. Also the salt water will definitely throw the impedance off some depending how much salt is in the water. If you are using resistors they should be non-inductive type and mineral oil is far better than any kind of water to cool them in. I hope you don't plan to run much power into it if you are using a pair of 1/4 watt resistors.
Write your reply...
