Who needs Hi-Fi and equalizers, when you got something like this? This President Lincoln is only 6K wide but sounds very natural with the stock microphone.
It's set up to pass 6000 Hertz of audio with a 2khz cushion on either side, but you're noticing the limitation of the stock microphone and narrow banded receiver. The Contour of the roll-offs is set internally similar to what you would do with an equalizer except it's set it and forget it and totally idiot-proof so the customer never needs to touch anything.When you say 6k wide do you mean total AM bandwidth or the transmitter is passing 6khz of audio?
That's what happens when you're listening on a narrow banded receiver. That receiver is getting sent back to Mike for the third time and hopefully he gets it right this time. I guess we'll find out sometime in the next week how it turned out.Sounds like space shuttle audio....
Whoever that Joe guy is he got a screaming deal on that radio and I'm sure the guy that sold it to Joe is probably kicking himself in the butt wishing he hadn't gotten rid of it.
This is all a particular type of B.S.
If a station sends 4KHZ and I can only hear 2,8 of it , 30% is missing.
Specifically the upper 30% .
If the voice energy is spread flat across 4Hz Then I'm only recovering 70% of the transmitted voice and energy.
So if a station wants to occupy 1.2KHz more bandwidth that I and many others can not hear it's a waste of bandwidth and transmitted energy.
Since I can't hear it I really don't give a rats ass.
However, when I can hear it as interference under crowded band conditions I hear it as the 30% of the voice energy that is specifically the highs of the voice range.
Instead of being 3KHz away to avoid interference I have to be 4 or more KHz away.
Now multiply that by how many ever transmitters are using ESSB and it only takes three stations to take up the space of 4, 6 stations to take up the space of 8...
The original purpose of SSB communications was to use less bandwidth and maintain intelligibility while using less energy to do it .
Now promoters of ESSB want to waste bandwidth and energy in the name of HiFi audio.
Buy an FM broadcast station
There are no specific laws about transmit bandwidth
95.973 CBRS authorized bandwidth.
Each CBRS transmitter type must be designed such that the occupied bandwidth does not exceed the authorized bandwidth for the emission type under test.
(a)AM. The authorized bandwidth for emission type A3E is 8 kHz.
(b)SSB. The authorized bandwidth for emission types J3E, R3E, and H3E is 4 kHz.
Yeah actually there are. For CB it has to comply with FCC Rule 47 C.F.R, Part 95
When it comes to amateur radio, hams in the USA must rigorously follow the bandplan as set out by the FCC and that band plan specifies bandwidth for a set range of frequencies within each band. The SSB section is limited to 2.7kHz.
You may be right about cb. The debate about am and ssb bandwidth on amateur radio has been beaten to death, some people think operating AM outside the "am window" is illegal. Can you post a link to a law that states 2.7khz?
