You're obviously using the heil with a transmitter/tranciver.. Whats the operating conditions?I dicked around with the mixer for about a year, Then I just bought a Heil PR781 and everything works fine now, LOL
Well if conditions are bad, I can't get out at all no matter what I do. My antennas are too low down. Using the 802 I had too many jacks and wires hanging around. With the 781 I just use the mixer settings in the receiver.You're obviously using the heil with a transmitter/tranciver.. Whats the operating conditions?
I saw Bob hiles video about using mixers on trancivers that don't have a f 2.9 for transmitting and the little difference it will make.Well if conditions are bad, I can't get out at all no matter what I do. My antennas are too low down. Using the 802 I had too many jacks and wires hanging around. With the 781 I just use the mixer settings in the receiver.
Note a Beringer 802 is not a mixer to use, its a toy, look at the cut off specs, you need at least at 3 channel equalizer to enhance the Mids. Playing with the 802's bass is ok but the high channel doesn't give enough range. However I do use the 802 for Karaoke, the kids love it!
I'm using a madiison with an SM 58 and as you know the Beringer 802.. When exactly is an eq compressor and, how would that get plugged into what I already have. Could you also tell me what the compressor/eq will also me to do. P. S. It's not the money. Had I known I could have gotten something that would actually improve the audio on my Madison I would have gone ahead and got it. At this point I'm not sure if I'm going to add anything to this setup and will probably just go ahead and do what many CB radio operators have already done and continue to, which is purchase and HF. Your answer would be appreciated as I still would like to learn even though I might not consider adding anything else to my station as an option. Thanks for your input. 73Just use the mixer as a preamp, then ad eq,compressor ect...
The best thing for starters is to ask people who know you how you sound over the air. Hopefully the will helpful on getting your settings correct. The SM 58 mic is good, but the Heil 781 is better, it's up to you if you want to spend $150.I'm using a madiison with an SM 58 and as you know the Beringer 802.. When exactly is an eq compressor and, how would that get plugged into what I already have. Could you also tell me what the compressor/eq will also me to do. P. S. It's not the money. Had I known I could have gotten something that would actually improve the audio on my Madison I would have gone ahead and got it. At this point I'm not sure if I'm going to add anything to this setup and will probably just go ahead and do what many CB radio operators have already done and continue to, which is purchase and HF. Your answer would be appreciated as I still would like to learn even though I might not consider adding anything else to my station as an option. Thanks for your input. 73
Like some many questions asked so many different answers are given.The best thing for starters is to ask people who know you how you sound over the air. Hopefully the will helpful on getting your settings correct. The SM 58 mic is good, but the Heil 781 is better, it's up to you if you want to spend
$150.
I
From your answer I'm guessing you believe one can achieve decent results from a Beringer 802 sm 58, interface and a uniden madiison? I'm going to purchase an HF shortly and won't put anymore money into my setup.
I must say that no matter the replies saying nothing good can come from using the equipment I mentioned my reports have been for the most part positive..
Most reporting my madison sounds much better with the 802 and Sm 58 than it did with the silver eagle.
A few reports even saying the setup sounds as nice as some hf's.
The one report saying outstanding came from an operator on a yeasu 1000 MP.
He was quite impressed. I guess it is possible to get a good sound from a mixer, studio mic and an 11 meter 30 year old CB radio.
Att least this is my experience.. 73.
How is the built in reverb on that 1002fx unit? Can you get the delay time really short?
Many, many Ham radio operators run a slight digital delay, they just won't admit to it and say "Oh, must be my room acoustics"...yeah, right
