Whoa! Ok, we're in a shotgun mode here...
It may be from other components you haven't even thought of yet.
Lets' see if you can take a look at the TX Strip - it may be a failed cap in that strip that is causing the feedback.
Again above and behind - so slow down, I know you want it fixed, but one thing that did happen is you swapped in that radio into another antenna. So if stability in one location was good, we cannot guarantee the same in all locations it's used in.
The 1K pot? Yes, knowing it's a "dual" final radio - loading of the circuit does change, the adjustment is different - you obtain higher RF power with same Test point voltages you'd use with a SINGLE final design, so relax, we're on it...
Locate C174, it was originally a 2.2uF - replace it with a Fresh one....50V (50WVDC)
Since this is a DI model - some changes have occurred so I'll need to know if other changes were made in other areas - but that's for later - just do the C174 thing..
