Ok so to clarify my last post, the radio isn't transmitting FM on FM only receiving FM on FM and still transmits the AM signal with the mode switch on FM. With another radio on close and with the mode switch on both radios on FM the di 55v is transmitting AM on FM mode. But we might have disabled it? I'm not sure my 55v that does work will transmit FM on FM never tried it yet.
Nice, ok then let's slowly put the radio back together.
But again look for that oscillation. we may have missed a step earlier. Went back thru a lot of posts here. TR34 and TR53 work together.
When you switch to FM, the C191 cap, the side that goes to the MIC amp - goes high - gets straight 8 volts ON THE AUDIO Side, not the AM Regulator - so you'd be able to adjust AM power this way, and FM power too, so to see AM and FM working the same power level - kinda brings me back to that front panel and it's switches again.
So if you switch AM to FM, you quench C191 with a lot of DC to wash out Audio... C187 keeps it from going back into the Mic amp.
The audio then re-routes to the new path of least resistance...
The PLL then sees a signal from the MIC amp - as an AUDIO signal. Thru C126, R160, Balances with R123.
This was part of the reason for removing TR53 to see if the envelope control was even there. FM works, but you have the AM component - so the 8 volts the Mic amp line sees at C191 - then tells us that it "quenches" that line - if you notice, there is another cap that is UPSTREAM - towards the Mic Amp C187 - that blocks the 8 volts from that AM/FM PA switch from damaging the output and trigger false positives on the RX/TX lines too.
This method of holding the line high - silences the AM audio from ever getting to the AM regulator. It washes, swamps it out - so the only place it can go now, is to FM mode thru C126 (another cap that can leak)
Pulling the Mic amp connection was another reason, we have to remove any possible loops that may cause this condition.
We've established it is.
You have help isolate this problem to traced to the switch your AM/FM PA one - this may be the very problem you have.
Locate S502...I think you have this board...
Take it or leave it, this may help...
Or C126 as leaking the audio signal to the FM side. This can cause a loop condition too...
IF that switch is bad, then the problem with the external was related in a way to this failure.
If the FM side cap - C126 - if its; leaky, or that lines been worked on - (D31 and D32) the loop can form from the FM side "awakening" when it shouldn't.. There is no "switch" to stop it except AM and FM and the PA modes the S502 (and all it's poles) sends voltage arriving to C191 from that switch and the other pole of the switch that also TURNS OFF(ON) the FM RX IC and Uses D31 and D32 to allow for, or stop (quench) Audio from going to the PLL and ringing with the Varactor. BUT THAT IS ON (8 volts all the time) in RX/TX modes
To take out TR53 and TR34 shows us the loop problem is not there...you can put them back in, we'll have to go at this another way if this condition still exists.
