B
BOOTY MONSTER
Guest
thanks marconi . ive got four 6 ft sections of aluminum tubing that i can make a maximum 23 ft long element out of . i have 1 inch , 1 1/8 , 1 1/4 and 1 3/8 inch outside diameter sections . i could just get two more 6 ft sections in 1 1/2 and 1 5/8 diameter that will allow up to a 33 ft 8 inch element . more than what would be needed , but it will keep the taper pretty consistent , and of course i can adjust the length since its all telescopic .
what i would PREFER to do is use four 3 ft sections at the bottom ( 1 1/2 , 1 5/8 , 1 3/4 and 1 7/8 ) because it works very nicely and cleanly with the mounting idea i have in mind for attaching to the mast . is that enough difference to be a significant problem ? or is it something that the gamma will compensate for when tuning it ?
i want to use the four straight 56 inch long 3/8 inch solid aluminum rods from my current ground plane for the four elements to make the cone . ill order eight 1/2 inch x 3 ft tubes to go with them since the will fit over each end nicely and then i can adjust anywhere from 72 inches to 120 inches for the basket element length . the 1 inch x 1/8 inch aluminum strip from lowes should do fine for the loop i think . their 8 ft length with a 1 1/2 inch over lap wil make a nice 30 inch loop . ive still got the loop i made the maco copy on the wood 2x4 , i could use that to add to it if a bigger loop is suggested or to try on my own .
and yes bob85 ... ive got what i think will be a pretty physically small idea in mind for attaching the bottom of the cone elements and SO-239 to the vertical .
