Several times I heard Freecell describe the radial cone on the S4 as a large expanding version of the coax, a continuation if you will right up to the bottom tip of the 1/2 wave radiator on top. He went on to claim that the angle of the elements relative to the radiator produced a very smooth transition of the coaxial currents, just like the coax, right up to the bottom end of the 1/2 wave radiator above...and I believe him until I started trying to understanding more about feed lines in my casual look at "Reflections II."
Does this sound reasonable from one of the old guard supporting the S4 design and its merits above all other CB verticals in its class? Can you explain?
Does anyone believe, as a result, we see common mode currents at play in S4 design and the CST animation? Can you also explain with a few words?
Can you explain how the current develops in the cone and where it emanates from and goes to...besides the obvious?
Can you indicate where we see high current points on the radiator inside of the cone, the upward slanting elements of the cone, and the top 1/2 of the radiator.
Using the animation still below, can you generally indicate, with words or an image of you own, any idea of the current magnitude and phase sign using the color graph provided? If you understand the graph then please indicate the phase value in a/m as noted, and the sign of the value where you think it goes on the image.
For example: the red tip might be - 0.0476 a/m or the middle of the top 1/2 wave might 2.37 a/m, etc., for the areas around the cone too.
I'm just curious what other's think.
