I tilted the antenna down yesterday to adjust the gamma match and take some measurements. I was able to get the SWR to 1.2:1 across the band. With 1.4:1 on ch40, it would end up even higher at 27.555 so I guess this is a good compromise.
One of the tuning points given in the instructions is for 27.185 and it specifies L1 at 930mm and L2 between 630mm and 640mm. My original setup had L2 at 635mm. I played around with the L1 and L2 values until I came up with L1 at 905mm and L2 at 650mm.
Here are the measurements I took. If any other measurements are needed by anyone, just let me know and I will tip it down and throw a tape on it.
Egg beater diameter: 68mm, 2 11/16 inches
Radial length from top end to center of bolt hole at the hub: 106 3/8 inches
Bottom of radiator hub to top of egg beater: 26ft, 7 1/2in
Hoop diameter (approximate) 30 1/2 inches
Dog bone for gamma match inside measurement: 5in
