So your saying if I screw mine up but over driving it. It's going to cook my transistors.. not that you actually see anything wrong in my pic that I posted..
So run it low and don't shoot for max..
Don't make me start to ask you a lot of questions...
The advice I gave you is simple, straightforward common sense -
Please tell me, you don't stomp on the gas on your new car do you?
Run it with the cheapest, stale-watery gas you can find?
If you do, then you're asking the wrong guy...
Then heed the advice me and several others have given.
Including the 4X rule - that being the amp will take the radios power - carrier, envelope - et al. and produce it nearly identical in every aspect, except it will be a lot
bigger, larger, stronger and
heavier. <<<---See? 4 -words that also equate to the level of expected ratios of drive to power - since antennas, vehicles, homes, coax, power supplies and all the assorted accessories play a role - and the sheer variety of these combinations is near infinite number - to each their own - the setup you have will be different than another - even with all events being equal - location - grounding - soil composition and conductivity for image and counterpoise all play a role in that amps PERFORMANCE.
If you put too much faith in thinking you need a lot of energy to get a lot out of it, then you have missed the whole point of even buying that kind of amp. Return it and exchange it - place, or duct tape, instructions on it saying something to the effect "I want people to hear me key up on the Superbowl" - and watch your credit card activity for the next few months, you'll either receive a refund or a series of extra charges will be placed as the options and accessories get added to your package request.
Apparently you are not seeing it...
Notice the vertical card? In my photo and situation, this is what makes T/S different from all the others and why you are pretty much dedicated/screwed - you pick - to the hobby when you buy one of these things.
Welcome to Grey Market Advertising...
That Vertical card is a CW tone and Oscillator board that connects a Key to make the amp key up in CW mode using a Xtal you choose for 10 meters.
Right now, the amp does not work because it has no Crystal in it. To use it requires a Key. So therefore it satisfies a basic requirement that you can sell equipment that can contain an amplifier - but is not able to be used on 11 meters -
IN ITS CURRENT FORM.
Doing the work, or having the work done, will violate the warranty and you are now stuck with an exchangeable item, not a REFUNDABLE one - work was done...I lost my wallet on the fact that this amp arced and the shop it came from or went back to - fixed it themselves and sent it along with a BRAND NEW ONE drop shipped separately. (Here's your Money Mr. Star, send that item to this address, thank you Mr. OutComm.)
With that being said, you have an amp that contains a lot of what you see in the photos I posted. Now what makes you concerned is that yours is a little different. That is true, and also - the person SELLING the amp has done a conversion to make it ready for 10 meter or 11 meter - that choice is up to you.
This is why you have to be careful when you purchase any amp from sight-unseen dealers - I got two amps and kept the worst one - both did work and the user went on their way. He did have a General license to use it, so I'm not going to go down that road. But, I can take you on this little gravelly - rutted - less traveled road - right next to it. Referring to; no matter what, you now own it.
Another aspect to learn, is how well they stand behind what they sell. I can take the amp I have and verify every part because the maker has posted schematics, part lists, even part SKU numbers to order replacement parts - thanks to CB Tricks - we have a means to repair it - what is your story?
Now, what questions do you have for me? Because you may have to go back into that amp and take a pic or two with greater details so you can show me your concerns.
