Getting back to the review after a vacation and some time away from home using this little radio quite a bit.
Wow. That vox trick works? So basically I just need some software, a couple simple wires and a computer and I'm good to go?
Yeah, it will work using MixW's TNC serial port bridge. I've actually done this with another radio, although instead of using VOX to trigger PTT, I used CAT.
Memory Operation
Before I go into details of how the memory function works, I'll cut to the chase and just recommend spending the extra $18 on the cable and software. It will make your life much easier. Don't get me wrong: it's not
that difficult to program the radio, but it could be better.
The instructions for memory programming are in the manual under the heading,
"Setting Memory Channels: Setting Co-Channel and Dis-Channel (MEM-CH)---MENU 27". I don't know what a "Co-channel" and "Dis-Channel" are, but after fooling around with the radio and following instructions, it becomes apparent that they're talking about receive and transmitting channel
. I'll try to provide some simpler instructions than the manual gives.
First, turn up the radio volume because you're going to need to hear the voice prompts. Now, input the receiving frequency, complete with any tone or DCS squelch setting. Then, you hit the MENU button and select the MEM-CH menu by either rotating the dial on top or just punching in 27 on the keypad. Hit MENU again to select the memory channel number setting and rotate the dial (or use the keypad) to select the memory number you wish to write. Hit MENU again and the radio says, "Channel Memory, Receiving Memory" on the voice prompt. Now, if the transmitting frequency is the same as the receiving frequency, you can just hit MENU twice and the radio will respond by saying, "Channel Memory, Transmitting Memory." Otherwise, hit the PTT button to exit the menu, input the transmit frequency complete with any CTCSS or DCS setting and go back to the same menu, and repeat the process above to write the transmit frequency. (MENU, select MEM-CH function, hit MENU, select memory channel number, hit MENU again).
One important thing to understand about the memory programming is that the radio does not seem to use the offset direction or shift direction setting to handle the transmit frequency - you have to input it manually using the procedure above. Other settings like TX power level seem to take effect. You can also name the memories using a menu setting that is very easy to understand.
The quickest way to enter memory mode is by hitting MENU then TDR. You can also use the MENU settings to toggle the frequency display between memory number, frequency, or memory name.
Next up in the review, a few interesting features and a summary of my feelings on this radio.
