I picked up a Uniden homepatrol HP-1. I have been using a 22' 10m antenna on a 20' pole to scan my local VHF & UHF stuff and LAPD which is a few towns over from me with success. Last night I took down that 10m antenna and put up a Diamond CR320A and ground plane kiton the same 20' pole. so far it is working a bit better than the 10m stick but, I was wondering if i would have better wide scanning using a SCANTenna Discone on the same 20' pole?
This is the antenna I am looking at getting:
Antennacraft by RadioShack ST2 Scanner Antenna Kit with 50 Foot Cable (ST2) from Solid Signal
I listen to voice from 37mhz through 1200mhz. P25/AM/NFM
