Yep, that socket will work fine. When you install the PLL, you have to install it so the dot on the PLL chip itself matches the location of the dot that's screened onto the board. Since you are installing a socket, you'll want to install it so if the front of the radio is facing you, the writing on the PLL chip is upside down. See pic below. Hope this helps.
~Cheers~
Can the following chip work on my cobra 142gtl MB8719 8326 C85? thanks.
