ok, the TX light isnt supposed to light when you are in PA mode, so thats all good.
the next step is to find out whether you have RF coming in, or whether the audio is being lost somewhere on the way to the speaker.
the easiest way to determine this is by using the radio's S-meter. if you see the meter moving with signals, but you cant hear them, then its an audio thing.
if you dont see any signals coming in, then its an RF thing.
if you have a parts radio, doesnt matter which type; then remove the S-meter from it, solder some 12" long wires to it, and solder some alligator clips to the wires.
then remove the wires from the 142's S-meter, and clip the alligator leads to them.
now you have an external S-meter to use for testing.
we need some way of narrowing down the area of the problem, and this is the first step.
also, with a radio this old, the electrolytic capacitors are very suspect.
if this is a radio you plan on keeping, and not just a "learner", then i highly recommend replacing all of them.
you can buy a kit on ebay for this.
heck, you may find that after replacing all the caps, your problem is gone.
one thing though, the radio will need an alignment after replacing the caps, so you'll need some test equipment eventually.
