kaos, i think we are going to need some pics to make sure you have the PLL installed correctly.
take a pic of the component side of the board and the solder side of the board.
you installed the socket with the notch facing the opposite way than it should have been, but that doesnt really matter as long as the chip is put in correctly.
i only mention this in case you chose to line up the notches on the chip and socket.
i understand that you are wondering why the radio seemed to TX with no PLL chip, and now it does not.
the PLL chip is responsible for generating the frequencies that the radio operates on, and without it, the radio has no way of "making its own" transmit frequency in the CB band.
the fact that you are seeing the radio "key up" with no PLL chip in it leads me to believe that there is something more going on here.
you said that the radio had a freq counter connected to it at one time?
how did you discern this?
how exactly was this old freq counter connected to the radio?
do you have the freq counter?
it is possible that the chip you got from china is bad. do not install the other one until you have more of an idea what is going on.
you may blow it and be out of luck.
i do have to say, and i mean no offense by this, that you are probably in over your head with this radio.
PLL problems can be real pains in the ass for people that know what they are doing, and if you dont already know what you should be looking for, it will confuse the hell out of you.
if you want to get help here, you're going to need to make a couple of very detailed posts that include voltage measurements on each pin of the PLL, every part you have either removed or replaced in the radio, every detail of what you found in the radio when you got it, and as many pics of this chassis as you can muster.
you are also going to need to buy a freq counter. not the one with coax connectors on it, but one that has a BNC jack on the front.
you are going to need it to confirm that the problem does indeed lie in the PLL circuit and not in one such as an oscillator.
