Cobra 89xlr
You're going to need some test equipment such as a decent DVM, watt meter, and a 50 ohm dummy load - for starters. Then, you are going to learn how to troubleshoot. You will also need to understand how different kinds of components work and reading a schematic.
The most likely cause for no transmit begins at the mic. Is it wired properly? What happens when you key the mic; is the TX light changing? The next most likely culprits are the driver and final transistors failure. This is where troubleshooting comes in. You will need to learn how to test transistors and other components, and diodes. Then everything in between. It is no walk in the park . . .
Sonoma posted a link to a cobra bulletin that outlines a diode swap of d14. It lists the serial number that the factory made the change. Transistors are tested just like diodes. It is easy, and only a google away.
