There could be two things wrong, pretty much, either the 2SA1012 has gone fault, or possibly the audio IC, upC1182H. If you have receive audio, the audio IC won't be the fault. If you have no receive audio, then the audio IC could be fault, as the TX audio on AM and the RX audio are ran thru the audio IC.
Hope this helps and good luck!
~Cheers~
Well changed out 473 and still no AM audio.
