The 2SA1012 is located right by the socket where you plug in your 12 volt source, on the back of the radio. It should look similar to a 2SA473, but labelled A1012.
Yes it is marked but TR44 is not marked TR42,43, and 45 are all right there. Guess thats why I was having trouble finding it. I really appreciate the help.
The GE69A is the same thing as a 2SA1012. That's the part that could be suspect. Remove that GE69A and replace with a 2SA1012, NTE153, ECG153, TIP30, or a TIP62. Any of those will work for replacements. Good luck!
Might try pulling TR-43/2SB525C and test it with the diode test function of your DVM. Had a similar problem on one radio I worked on awhile back. Using a schematic can help; just follow the path . . .
Pulled the Sb525 out and if I am testing it right it shows bad, so where is the best place to get one or the substitutes of 2sb809,bc327,bc328,bc666,bc638?
Dont really want to make a $25 order or deal with the ebay clowns for a $2 part.
Please advise me to what is a good replacement mic for my SR-497HPC... Answer: 497 is "wired like Cobra", so many choices available. That radio does not need a power mic, so purchase a stock "coffin style" mic with a decent cord, like the ones that Astatic uses. The Superstar DM-507 is my go-to. https://www.ebay.com/itm/3050474478...adANq91JSiEEnz8EGqPJRBloTgEyaVsBoCtoMQAvD_BwE $12.99 + .99 cent shipping.
