Utica, Town and country 111 cb radio. shorting out.
Been stuck at home, used the diagram sample you posted, since all my Sams books are at work. Kinda depends on how the control is hooked up. If you posted the part of the schemo showing the receiver and RF Gain control I would venture an opinion. But if you look at the Sams diagram, you'll see an arrow alongside the symbol for a front-panel potentiometer control. The arrow points to the clockwise end. A 10k fixed resistor wired to the two outside terminals takes care of that. The wire for the center lug just gets moved to the end of the control where the arrow on the diagram is pointing.
Reactions: unit_399
Thank You my friend, here is one of what appears to be a few different schematics. from the v1 tube pin 2(cathode), follow it to the rf gain.
  • Utica TC3 Schematic - Schaltung Diagram (1).pdf
I'm looking for a 10k resister. lol I found a 12k that measures 11.8. I think i'll try that . it still has no receive daggonitt.
Oh sh.. My apologies. That was something i got off the internet. it looked good but it didn't magnify very well. i'll take a photo and load it for you my friend. Thanks Nomad. here ya go is that better my friend.IMG_4441.JPGIMG_4442.JPGIMG_4439.JPG
I tested around and I realigned A15 A14, A13 A12. some of the lugs don't work, A15, and the top lug 14 of 14/13. also, v1 pin6 should be 75vdc. its 152vdc. The 5pin should be 115vdc, its 153vdc. I know we can fix this dang thing my friend. It's gonna sound great with my sure 444D i can see the meter swing. It dead keys about 7-8 watts And it really pegs the modulation meter on the radio Thanks lol
I get a nice loud tone when i set up to test a1 thru a8. The 266khz signal is connected to pin 4 of a5,a6 transformer The vtvm doesn't move much though. maybe the problem is between, the a5,a6 transformer, and the anntenna.
i found v1 pin 2, and v5 pin 2 have about 40vdc. It should be .6 vdc and 3 vdc. The rf gain is on this line. I can't figure out where the 40vdc voltage is coming from. any help would be very appreciated. Thanks
Shoulda pointed out the ultimate test for the RF Gain control. Just short across it with a screwdriver tip or gator-lead jumper wire. At the full-clockwise position, the RF Gain control is at zero ohms. The reading on V1 pin 2 suggests you are not getting a current path to ground through the RF Gain control, or there's a physical break in the circuit between V1 and the control itself.
I got the numbers right on v1 and v5. by clipping to ground at the rf gain. still no receive. though
I still have no receive. dang it. i checked the tube voltages, they seem to be good. i think i will trace wires from each pin to look for the problem
Does suggest that one of the two crystal oscillators needed to receive is not running. Do you have a ham or shortwave receiver that can tune in M24 at 9.979 MHz? Or the selected crystal on the channel selector between 8.36 and 8.5 MHz?
If either of these oscillators is shut down, that's what's blocking the tracks.
Okay thanks Nomad. i will check that. my friend when i was hooking up the signal generator on the bottom side to try another alignment the negative touched something pop. and went off . now it has no ground to chassis. i cannot read anything using chassis for ground. i tested 2 red wires connected to red/yel. they are 38ohm correct. so far okay more to check though
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
