The WDX Club is having a 24 hour CB DX contest on December 13th! The object of the contest is to make contacts with as many WDX Club members as possible and also to promote the website. Member Binrat has graciously volunteered to be the new club contest coordinator (thank you Binrat!)
Here are the details:
- Only contacts with other WDX members count in the contest. The roster may be found here
- Channels: 34 AM, 40 LSB
- Date/Time: 12/13/14, 0000 Zulu through 12/14/14 0000 Zulu. If you're not sure how UTC time works, please ask! (For the majority of club members are in the U.S., this means the contest starts Friday night and ends Saturday night)
- Logs must be posted in the WDX Club Contest Contacts forum by the end of contest. Create only one thread for your contacts. You can edit or reply to your own thread, using it as your log throughout the contest. At the end of the contest, the contacts forum will be locked, so make sure you upload all of your contacts before the end date/time.
- There is a 2x multiplier for mobile, portable, or maritime contacts. If you operate as mobile, maritime, or portable during the contest, you are credited with the multiplier for any contacts you make. If you operate as a base, you receive a multiplier for any contact you make with a mobile, portable, or maritime contact. Make sure you clearly designate these in your log
- No amplifiers allowed, CB legal limit.
- Contacts will be verified against each others' logs
- This is an "on your honor" contest and intended to be fun. Please play by the rules
- BE A COURTEOUS OPERATOR, PROMOTE THE SITE, AND MOST IMPORTANTLY HAVE FUN!
