Wow!!! Galaxy LC 998v most expensive export?
Discussion in 'CB and Export Equipment and Accessories' started by undertaker, Jul 12, 2017.
  1. undertaker
    undertaker
    Expand Collapse
    Undertaker
    Apr 5, 2006
    1,542
    380
    This radio claims to do 800 plus on the bird meter. 900 if you have a 100 watt power supply...
  2. BBB
    BBB
    Expand Collapse
    Jan 17, 2012
    729
    355
    One Off radio by Lester...not mass produced.
    [​IMG]
    rabbiporkchop likes this.
  3. rabbiporkchop
    rabbiporkchop
    Expand Collapse
    Jan 18, 2007
    1,319
    349
  4. undertaker
    undertaker
    Expand Collapse
    Undertaker
    Apr 5, 2006
    1,542
    380
    Well the radio is 1299.99 If you want red dot Toshibas it is 100.00 more!
  5. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    725
    107
    I saw a video on youtube, not sure if it was lester customs or someone else, they guy was having ( not red dots ) Toshibas installed in his 2970N4, plus a few other things. Im thinking and guessing to have just the toshiba transistors put in is parts + labour = ?
    Then I was looking at a Jokerman video, and he was testng some Toshiba transistors which were apparantly rated at 105 each, some were as low as 90W each, sad. He was pissed off .
  6. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    725
    107
    darango360 and rabbiporkchop like this.
  7. rabbiporkchop
    rabbiporkchop
    Expand Collapse
    Jan 18, 2007
    1,319
    349
    His most recent video should stir the pot and raise some eyebrows regarding receiver sensitivity and cable length.
    Limeybastard likes this.
  8. 543_Dallas
    543_Dallas
    Expand Collapse
    Jul 25, 2011
    1,239
    1,210
    A 4 pill class C comp amp with a good cooling system running at 900 watts will eventually will eventually fail if you talk on it very often. He's put those 4 transistors on a smaller heat sink without much cooling. Hopefully he didn't bias them class C for efficiency because it's a ssb rig....but if they aren't ran in class C there will be even more heat to deal with. How about those IMD levels? That is a very expensive turd.
    kc0lrp and KD2GOE like this.
  9. rabbiporkchop
    rabbiporkchop
    Expand Collapse
    Jan 18, 2007
    1,319
    349
  10. 543_Dallas
    543_Dallas
    Expand Collapse
    Jul 25, 2011
    1,239
    1,210
    My post was about the 900 watt radio from lesters customs that started the thread. He's selling a 900 watt radio with 4 2sc2879s. Only $1300.
    http://store.lesterscustoms.com/
  11. undertaker
    undertaker
    Expand Collapse
    Undertaker
    Apr 5, 2006
    1,542
    380
    My stryker 955 is plenty good....
    338_MtRushmore likes this.
  12. Big Kahuna
    Big Kahuna
    Expand Collapse
    Jul 31, 2008
    180
    109
    "Wow!!! Galaxy LC 998v most expensive export?"
    It's the most expensive something.....:eek:
    kc0lrp likes this.
  13. Limeybastard
    Limeybastard
    Expand Collapse
    May 29, 2017
    725
    107
    Hopefully the day will come when prices will approx $1 per watt. In respect to amps etc.
  14. cbkidd1
    cbkidd1
    Expand Collapse
    May 3, 2005
    508
    54
    I guess it's all about what you want. And what your willing to pay for it. That galaxy has to have some heat issues. Sure is a lot of money for a wanna be ham radio.
    LeapFrog and kc0lrp like this.
  15. Troubleshooter
    Troubleshooter
    Expand Collapse
    Supporting Member
    Jun 13, 2016
    195
    47
    Definetly has heat issues... Just like the ranger rci-69ffb4, at least the ranger has toshiba pills in it , but drifts like a sailboat.. That little fan inside only does so much, the galaxy dx95t with the 2 pills also runs hot.. But if you tune them the right way and not try to squeeze every last watt out of the radio , they will run a lot cooler.. If it was me though, I would rather spend the money on a radio, like a uniden grant XL, cobra 148 GTL , lots of nice radios out there to choose from, and a separate amp. You will have a better setup for the money spent. (y) But that is just my opinion, what do I know.. :)
    Frank412015, kc0lrp and rabbiporkchop like this.
Share This Page
