Constant static on base..
CB590
W9WDX Member
Jun 29, 2016
1,545
1,265
173
Trenton Nj
www.590dx.com
Ok. Put up a A99. It's on 16' of 'top rail' post and about 32'6" to the tip..
The bottom of the mounting post is sitting on the ground.
All my ham gear and power supplies are grounded to the house ground via an outlet and I verified by meter to be grounded to the ground rod and breaker box which is like 6' away from the radios. My HF gear has some QRM but the CB has it worse IMO, like constant 2-3 on the radio meter.
I verified with meter the ground for the antenna connectors are grounded together as well between the radio and amp and everything else as well.
I turned off all breakers in the house minus and hooked up 14ah gel cell from my go kit.. and with everything off I still get 2-3 on the static.. this was just the CB being powered.. amp was not on at all.. static present unless I undo the coax from radio..
Now keep in mind I live maybe 30-40' from the power lines here.. just norm ones, not the tall monsters.. you can see the power lines in the pic to the right and the transformer.
My HF is an endfed with a 1-1 choke just outside the wall..
Also note I have not officially grounded the antenna post or antenna outside yet.. just propped the post up against the vinyl siding, used 4 mounting brackets, and put the A99 on top..
I do have 3 screws holding the posts together (shown in above pic), I can use one screw for a ground wire if needed.. or do I need to put a ground wire right on the A99 U-Bolt up at the top??
Thinking of a ground wire for antenna to run to a small ground rod in the dirt next the antenna mounting mast, and maybe try my HF choke 1-1 on the CB and see if that helps??
Any other things I can try that are free..
Reactions: Rwb
I got almost same setup lines close by also.but i grounded my a 99 and i dont get static.my a99 is clamped to belled pipe which i welded at every joint.i then drove a steel T fence post deep n used a grinder n shined it good and the pipes where they contac the T post coated bare spots with silver electric contac grease.migh try grounding yours.
Im going to take mine up 1 more joint of that pipe 5 ft joints
Move the a99 to a different spot, hook your HF rig to the a99 and see if you still get the static. If you do as I said move the antenna. Your end feed is horizontal and this is why your not hearing the static on it. Most electical noise is verticaly poleerized.
Reactions: Rwb
I was entertaining trying the HF rig on it where it's currently at.. easy Coax swap, can also use the MFJ941 to check SWR as well on the A99 maybe..
Moving the A99 is a PITA.. did by myself and again wife hates.me doing anything with any radio.. not allowed hobbies she said..
Reactions: Rwb and 357magnum
A99 is end fed antenna. That means coax acts as antenna, so pipe too. That is very bad.
To avoid is a must to make:
1. Choke balun right under antenna.
2. Choke balun at coax entrance to shack.
Balun - 11 turns of RG-58 on 2x FT240-52 cores (better) or 5 turns of RG-58 on 4.25" air cored (good for quick check).
Observe if during rain/wet soil static will be less. That means there is a problem with power transformer connections/grounding.
Mike
p.s. A99 is worst choice you could make IMO.
M
Mike
M
I will try my HF MFJ choke right below first. I can do that easiest to see if I get any change.
I didn't leave any excess coax to coil up.. ughh
Reactions: Rwb
You can get a 10ft coax to add to the top for a choke. Put a wire on the antenna mount and run it down to a ground rod. Ground your radios and amps to the same rod. Do not use the electrical ground for this. Check out my antenna and station grounds.
https://www.worldwidedx.com/threads/sirio-new-vector-4000-install.226677/
Good idea on making a choke and just adding on using so239-so239 to add 10' of coax..
The issue with that is radios/amps are on the opposite side of house as far as the grounding goes. And I don't have 150' of wire to go around my house to the opposite side.
I have no problem running a ground wire down from the antenna mount to a new ground rod or something..
I might pop the McKinley back in my pickup and see if static is as bad sitting in my truck about 75' from the same power pole while in my driveway..
If I don't get it there maybe I could just move the antenna more toward the other end of the trailer.. add more coax and a choke in the process.. I have another 25' of LMR240 here just need to add another PL259 to other end..
Just speculating here..
Reactions: Rwb
I agree about good grounding practices. My homebrew Star Banger Antenna is grounded via mast, which is 8'-0" in the ground. There is a 12 ga. wire running from the bottom of the actual antenna on the ground side, it is terminated @ a ground rod at bottom of antenna mast. From the pole just below ground level I have (4) 2" dia. pipes (about 3'-6" lgth.) welded horz. to the vertical 2" dia. mast (pipe) @ 90 deg. From the ends of the horz. 2" dia. pipes, 2" dia. x 2'-6" lgth. pipe (typ. 4) driven into the ground. The mast is also connected to another 2" dia. pipe (via a 1" dia. pipe) used for a 50 amp. RV pedestal which is grounded @ the pipe and through the electrical system to the barn. All pipe connection is butt-weld. Panel in barn is grounded to 8" dia. vert. support which is welded to the rest of the metal pole barn structure. Pole barn has 2" pipe verticals spaced 4'-0" apart that the sheet metal is screwed to. The barn is 30' x 40'.
The RV power pedestal and antenna are about 5'-0" apart. The 50 amp. direct burial (4 wires) had to be pulled back out of the ground due to water shorting system.....we created an over head line by extending to the RV pedestal vert. with more 2" pipe. So the antenna and the 50 amp. power are closer than the picture you have.
We have a receiver hooked up in the barn, old military unit, with a make shift long wire running out of barn and two coiled CB antennas sitting horz. on the tractor tire outside. All kinds of static and noise, but this radio is only grounded through the electrical system (if that). Belongs to my friend who is older and more experienced in radio, but just can't seem to figure out why he has so much static. Buzz effect, comes and goes. Can't seem to beat grounding into that old goat.
Now my radio is out in the RV. No static, crystal clear. Even the AC unit does not bother reception and the antenna pole is only 5' away. I attribute my clear reception to the multiple grounding locations. I have no chokes on coax, antenna tuned 1.2/ 1 swr.
Reactions: Rwb
You can ground and add chokes until the cows come home. Won't do a thing for radiated broadbanded RFI.
Both of these radios are coming off same electrical system. Now there was a transformer replacement after Harvey. Transformer is not as big as original. We have another theory about the grounding at the neighbors house. Many factors can play.
Currently have your link playing. Damn that's good.
https://www.youtube.com/watch?v=Yan9WilVmEg
Reactions: Rwb
You have recording of your noise? Transformers are rarely a source. Once they start arcing, they'll go boom. Loose hardware on them, can radiate. Cracked insulators usually crackle when raining. Try calling your power company and ask to speak with their RFI guy. He/she should can quickly confirm if it's their problem, or something around you.
I've had very good luck tracking down RFI using an HT with AM receive and a dualband handheld yagi, Helps greatly, it the HT has an attenuator. You can damn near pinpoint the source. Only other thing that's more accurate, would be an ultrasonic locator with a parabolic reflector. Tune the HT down in the Airband portion. A regular AM radio with a good quality internal bar antenna is a good tool, too. You can locate the direction of the source by nulling the signal by turning the radio. Once you get a heading, then use you HT to track it down. These techniques work good for noise in the higher bands, but the source on lower bands can be very far away. You would need to use an oscilloscope to capture the signature in your shack, then drive around until you pick up the identical signal, which will be your source.
Reactions: Slowmover and Rwb
We have been talking about calling the VEC, you know how that is. When the guys came to change transformer they admitted the smaller transformer. We are along the coast in Texas and have had a lot of rain. It has increased. Receiver in barn is not grounded except by elect system. We figure the Co-Op installed too small of transformer to run power needs. I'm sure there is some RFI leakage from power supply. Just got to call and get a health check up.
Reactions: Rwb
Write your reply...
  • @ Crawdad:
    Looking forward to it Gary!
    4 DAYS TO HAMVENTION :love: :cool:
  • @ W4KVW:
    Condolences to Lee for the loss of his Mom.
