if i want to check my modulation i will use a modulation meter or a scope not a PEP meter!maybe you should take your own advise.![]()
I suppose you think I didn't know the scope is the best way to measure modulation? What you don't know is that the PEP meter is one tool that does many things. You look at the PEP meter and think "that's fake watts" because you don't understand that a 100% modulated AM signal contains four times as much power on positive audio peaks then the carrier.
