I am at a loss, maybe some kind of audio limiter on the mic socket? I will try some different microphones and see if I can make it any better.That's sh1tty waveform for sure. Raising carrier won't help.
I have an RFX95HD on my Galaxy 86v, works great, looks great on the scope in both AM and SSB. The Ares 2 is just different for some reason.I think it is the padding on the input side, I think the guys at palomar mostly intended for it to go on cobra 29s with cliped limiters.
I have recently had 3 rfx kits blow the electrolytic capacitor in them shortly after powering up the unit the first time, after I change the cap no more problems. I run my bench at 14.8 because that is what many of the trucks provide to the radio and I like to tune at working voltage but that should not have blown the supposedly 16 volt cap/
I think @Tim Chambers was working on a way to do it. Maybe he can give us an update.Did anyone ever figure out a proper npc for this board?
Just randomly ran across this.
I know I am the minority voice that is not a fan of the RFX series of bolt on amps on this forum! That said way to go! You did it yourself and you got an outcome you can live with! Cheer's! All the best!At the risk of making a big radio even bigger, I put an RFX95 on my Ares 2. The installation is not too hard, and the directions that come with it are pretty good and fairly easy to follow.
When you take the heat sink off, you will find that the transistor mounting screws thread into it. I ended up buying a small nut assortment from Amazon. Don't tighten them too tight, or you will crack the ceramic insulators. Firmly snug will do it.
MCMASKE 300PCS Metric M1 M1.2 M1.4 M1.6 M2 M2.5 M3 M3.5 304 Stainless Steel Hex Nuts Assortment Kit for Screws and Bolts
Amazon product ASIN B0B7SLDHK1
