Check voltage on R111 feeder to Mic Amp from TX switch. Both sides should show voltage - else C94 10uF50V may be failed if R111 show volts on one side - dead on the other.
Not a lot of people would really understand if anyone whom needed to repair a radio - was simply told - we replace all the caps and that will cost you $$$ amount ON TOP OF the cost to troubleshoot, repair and replace any parts that have failed.
This thread is; if not a good one, an example of cascaded failures - kaos is currently dealing with a lot of small fires as it started out with a voltage problem has now escalated into such an event you describe due to the original problem that caused all of this.
VR5 - and when it's (modulation is - that is) low like that, you have polarized caps in there too - so observe polarity - for Limiter works on potentials below Foil Board Ground.
A former project, hope this helps! Caution though - PC 68 but applies theoretically to PC66
