What are you using? A blow torch?!? lol
Dark spots don't hurt anything; but I hope you are doing better than that by now.
Make sure the tip is clear of crud, I sometimes use a wet sponge and twist the solder iron tip into it, & wipe away the crud.No a 25w soldering iron and solder won't stick at all
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
