Cobra 148 gtl china model
the schematic shows a R130 resister in that circuit so not sure what to tell you. maybe Nomad will have some info for you. you might look at what he left you yesterday.
check the 3 legged trans on the side case that feeds the voltage to the radio about 9 volts. I think Nomad mentioned it also. about 13 volts on the rear leg, 0 volts on the center pin which should be ground and about 9 volts on the front leg.
